this is for the Hyundai Rally barge?
A - use the port in the block where the current oil sender is. flex line to a brass/alloy block mounted somewhere and screw the new gauge's pressure sensor into that.
B - fit external cooler sandwich adaptor between oil filter & block, get adaptor that has two extra holes in the return-to-engine side, screw in temp and pressure sensors into those holes. That way you read the pressure/temp of the oil going into the main oil gallery and you have maybe 1 or 2 seconds more notice of running out of oil pressure.
Suggestion? fit a variable pressure sensor into the factory port and put a low-pressure switch @ the filter/adaptor. Then fit yellow truck-type side-running light to centre of console and wire it up to the sensor.
