Ive seen a few different figures in different manuals, but you should expect to see somewhere around 185psi. Anything below 165psi I would think to be getting a bit too low, although I think the manual states about 145psi is the absolute limit. And if its anywhere higher than 195psi then you either have serious problems or someone has been playing with the engine previously. Why dont you do a test and post up what you get?
PS: keep in mind you dont want any variation between cylinder readings either. Anything over 15psi difference may be worth checking out.
