Results 1 to 15 of 17
Thread: 7mgte help wanted
    Nov 2009
    tin can bay QLD
    Default 7mgte help wanted
    hi guys
    im doing a 7mgte conversion atm into a ma61 , i have all the stuff i need but im thinking about going to a piggyback or aftermarket management . what i want to know is there anyone out there doing plug and play looms for the 7mgte if so who, i have rebuilt the head ,1.2mm hks mhg,Garrett gt45r,fmic, 48 turboshit ex waste-gate, hks ssqs blowme valve, will i need bigger injectors (plan to keep boost around 14 psi )
    thanks phill
    Forum Contributor Domestic Engineer
    Default Re: 7mgte help wanted
    A GT45 is pretty bloody big turbo for a 7M. At your 14psi, you probably can't really make boost until 4000+rpm, and even then the turbo will just be coming onto the left side of the map. Sticking to 14psi, you will probably only make around 420hp, and won't have reached the efficiency island of the turbo yet. Unless you plan to rev the ring off the thing and make 1000hp, I'd say it is miles toooooooo big.
    And yes, you'll need likely need bigger injectors for even 400hp.
    What are your goals with this thing?
    Oct 2008
    TAS
    fark me dead, this thread needs more pics!
    1983 Toyota Celica Supra
    Nov 2009
    tin can bay QLD
    lol i will get some pics up for u , i only got the 45 because a mate pretty much gave it to me its done about 3.000 klms, it has a small exhaust a/r like .70 . my plans for the car hmm daily,skids,drags lol . mainly a daily to work and back , not looking to will hp heroes or anything
    so does anyone know of a pre made patch loom
    Nov 2009
    tin can bay QLD
    turbo specs
    Turbine Housing AR: A/R.68
    Turbine Inlet: T4 Flange
    Turbine Outlet: V Band
    Comp. Housing AR: A/R.70
    Compressor Inlet: *101mm
    Compressor Outlet :*65mm
    Turbine Wheel: *64.5-73mm Trim:64
    Comp. Wheel :*66-82mm Trim:44
    Oct 2008
    TAS
    is it still air flow metered?
    Nov 2009
    tin can bay QLD
    atm im trying to decided what to do , i have a 1uz afm here but unsure if i should go with lexus afm and a apexi safc,
    Oct 2008
    TAS
    Your prob better off with a full stand alone ecu such as a haltech or adapronic and a MAP sensor to replace the AFM.
    Although i'm sure your aware that people have had good results with lexus afm/550cc injector combo.
    It depends on your budget and goals. I'm sure who ever tunes it will prefer a aftermarket ecu to a piggy back.
    also, get this!
    http://www.toymods.org.au/forums/sho...23#post1322423
    Nov 2009
    tin can bay QLD
    yer i have been looking at getting it , i might just commit
    I would certainly look into full aftermarket rather than piggyback or fuel only adjusters. You'll want the flexibility to remove the AFM, dial as much timing into the low / mid range of this thing as possible to try and make some useable power down lower in the rev range, and possibly use the boost control to try and limit the ramp rate of the turbo to take some of the harshness out of it.
    It is still most likely to be a pure slut to drive, make a mockery of the MA61 chassis, and be slower than a car with a turbo half as big, making 2/3rds of the power.
    Sorry if I sound negative, and whilst if you can actually get this thing to work, I'd love to see it, I think there needs to be more thought put into matching components and desired goals.
    As for patch loom, I think microtech was making them at one stage, though I could be wrong. Any good tuner / mechanic / auto eleccy / DIY bloke shouldn't have too much trouble with this though. Just make sure of ECU compatabilities with sensors, as some don't interface with the stock Toyota ignitor setup.
    Can't swap the turbo for something more user friendly? Do you have an exhaust manifold yet or specific requirements for turbos?
    Nov 2009
    tin can bay QLD
    ok boxhead thanks for your imput , im am considering ether a microtech lt12 package or a adaptronic 420c just waiting for some pricing and what not ,
    do u guys think it is possible to run it on a safc2,Lexus afm, 550cc, from a budget side of things
    what turbo would u recommend with a t4 flange that's externally waste-gated/internally
    HP goal in mind?
    Nov 2009
    tin can bay QLD
    350ish hp overall im not really fussed to be honest as long as it starts and i can cruise around i would be happy
    Do you still have the standard exhaust manifold and turbo plumbing? To be honest, with that kind of power, it would probably be easier to highflow the CT26, and you'd get your 300 to 350HP at the tyres. This could also work with the AFM and SAFC (though I'd still think aftermarket is the way to go).
    Otherwise if you have to stick with the new manifold, I'm not sure on small framed turbo's with a T4 flange - someone in the know might be able to help with this one. Otherwise, you can always adapt the T4 manifold to T3, and run a GT35 or similar for that power goal.
    Nov 2009
    tin can bay QLD
    just be to a workshop and booked the supra in to get a adaptronic installed in 4 weeks ,
