Results 1 to 10 of 10
Thread: Need help - 1jz GTE vvti conversion
    Apr 2011
    Kuala Lumpur
    Default Need help - 1jz GTE vvti conversion
    Hi guys,
    I'm new here, my name is Rahim from Kuala Lumpur Malaysia. My project now is to install 1jz engine on my benz W124. Problem is engine can start but for only 5-10 second. Try to rewiring with diagram (I got it from Mr. George - Thanks) but still not working. My engine is 1jz GTE VVTI with ECU No. 89661-3A660. Try to unplug air flow sensor & clean up vvti, ETCS-i, but still not working. Guys, please give me idea or something - Thanks in advance.
    Default Re: Need help - 1jz GTE vvti conversion
    Rahim, I had the same symptom on first start of my 1JZ-GTE VVTI, it was the MAF or as some call it the Air Flow Meter AFM.
    Are you really going to run the engine without an intercooler as in the pic?
    cheers Chuck.
    MS51Crown Coupe,
    May 2007
    Quote Originally Posted by "Z" UTE View Post
    cheers Chuck.
    ide suggest there is a side mount tucked down there somewhere...
    Apr 2011
    Kuala Lumpur
    Quote Originally Posted by midnight_purple_GA70 View Post
    give me details please, dont know what and where is it.
    Apr 2011
    Kuala Lumpur
    Today I'm going to double check my air flow sensor, maybe the problem is there. Bro "Z" UTE, its only a pic, of course I use intercooler, not complete yet. Thanks.
    May 2007
    I Was refering to the comment chuck made regarding running the car without an intercooler...
    i would suggest checking that you have no vacuum leaks in your intercooler piping or other pipework
    Apr 2011
    Kuala Lumpur
    Wink Re: Need help - 1jz GTE vvti conversion
    Thanks, will make sure no leakage. Currently intercooler located near to engine with cooler fan (you can see it in pic, small intercooler for test) for temporary.
    Apr 2011
    Kuala Lumpur
    problem with engine stop after few second solve - problem with air flow sensor. Now problem no.2, throttle not function, check wiring - ok, guys, how to solve this?
    Apr 2011
    Kuala Lumpur
    Ok, I found the reason why my throttle not function. Someone change the TPS with other model - totally wrong. the part no. for TPS is 89452-30141 (now 89452-22090 - not function) help me if I'm wrong . Anyone have that TPS or know something about this please help me. Thanks
    Apr 2011
    Kuala Lumpur
    Done - change TPS - 89452-30141.
  1. Replies: 40
    Last Post: 04-02-2018, 07:44 AM
  2. JZA80 1JZ VVTi Conversion
    By Nat in forum Engine & Driveline Conversions
    Last Post: 17-01-2009, 11:42 PM
