From memory - the roof-rail rubber seals just pull out. They may be glued/sealed in place, so some care is needed to get them out without damaging them. The ones I did came out really easily. These seals are screwed in place at the front - should be obvious where. Once you've got the roof-rail seals out, the screws holding the chrome trim will be exposed. Remove the smaller chrome trim pieces that run under the "A" pillars (about 3 small screws). These are likely to be glued/sealed in place, but generally come away pretty easily. Then remove the long chrome trims that run up the A pillar, under the roof-rail, and back down the C pillar. These also will be glued/sealed in place, and are quite delicate (ie, easy to bend) so take your time and use some suitable tools to gently pry them away from the body. The chrome gutters just clip into place. Requires a bit of bravery, but basically you just pry them off with your fingers.
If you need to replace the roof-rail seals with new ones - try Spectrum Rubber (Sydney) or Scott's Old Rubber (SA).
Good luck!
Paul
