Great to see some discussion on this much overlooked topic, I need to do this to both my jzz30 (mount both sides) and my jzx91 (only has left hand side mount- same as your jza80).
One of the problems that you may come across is that apart from missing the rubber bush on the right hand side, the subframe is also missing the outer sleeve for the right hand side mount, therefore there will be nowhere for you to fit the new bush into.
you may also find that removing the old bushes requires them to be knocked back out from the front, ie, you may need to drop the diff head and push them out backwards. you may also be able to push them out fowards by knocking them from the rear, but of course they still won't fit out past the diff head!
I doubt that it'd be possible to pull them out from the back, they'll be pressed in place. it would be possible to cut through the outer shell with a hacksaw blade and collapse the outer shell, but in that case I think it'd be easierto just drop the diff!
In any case, sadly, it doesn't look to me like a 10 minute job.
I'm going to jump on the lathe and make up a set for each of my cars (and a sleeve for the missing right hand side mount) and will let you know how i get on with it and any improvement, but in the meantime, anyone else whos done this, you're input would be great!
