7mgte injectors are low impedence I belive, my 3tgte original injectors where high impedence. Do you have resistors in series with the 7mgte injectors if not I would seriously not run the car untill you do for fear of blowing the ECU injector drivers.
If the above is all goo you need to pull the top off the air flow meter (the black plastic lid. You will be confronted with a cog controlled by a spiral spring. You need to tighten this spring untill you get an appopriate air flow mixture. Note this is best done on a dyno. Also mark where the standard spot is so if you need to revert back.
Roger
