anyone.... !!!!!![]()
was sitting in a carpark. waiting to pick someone up when the idle became rough. and sounded like a wrx
Symptoms.
seems to be running on 4 . or very very retarded timing. as the cats were white hot after just putting the car home as slowly a possible in only 3 mins.
Rev counter was working at idle but disspears above it.
tried disconnecting each coil pack , starts and fires but will not run with either disconnected.. same goes for the ignitors
not sure if its connected but the car is loosing oil somewhere around 1/2 dipstick over 300kms less.
hoping someone has an idea or its off to the mechanic on the back of a truck :-( sigh.... only a week into soarer ownership.... not a good start.
1990 Aus Delivered Widebody GT4 Play 200 awkw
1996 HDJ80. turbo multivalve 80 series landcruiser
1997 HZJ80 Landcruiser Sold![]()
1993 Soarer V8 Manual Sold![]()
1986 Celica SX Sold![]()
finding the oil leak would be a good start, might be leaking onto a sensor or into one of the distributors...
1983 Toyota Celica Supra
Are the cats stuffed? If they collapse and block up it will cause rough running and they will get mighty hot in no time. Check for error codes?
EP82 Starlet GT - [URL="http://www.toymods.org.au/forums/forum-members-rides/71090-stus-ep82-starlet-gt.html"[/URL] SOLD
EP82 Starlet GT V2.0 - http://www.toymods.org.au/forums/sho...98#post1514198 SOLD
The IS400, GXE10 with 1UZ - http://www.toymods.org.au/forums/thr...8-StuC-s-IS400
i doubt it would be the cats as it want from fine to fucked instantly.... no idea how to check for codes on this... more research.
saying that... they are prob fucked now...
1uz's have issues with coil packs or igniters as they over heat/fail from being in close proximity to the engine. maybe ones being dicky and not firing consistently
the leads are a pritty common problem on 1uz's there hell tiny
99% of the time either one of the coils has died, or one of the ignitors has died.
Very common occurence nowadays.
Find a friend with a 1UZ and swap some parts.
was a coil. however coil was a dead short.. so killed the ignigtor too and something else apparently. meh ... makes more power than before now...
yeh it has the stock ecu afaik
