Results 1 to 15 of 15
Thread: Anyone know what box this is?
    Toyota for life REP! Backyard Mechanic TTV8RA23's Avatar
    Jun 2006
    Whakatane
    Default Anyone know what box this is?
    I need help identifying this box please All i know is its a toyota one.
    Any help is greatly appreciated.
    Simon
    Kiwi back yard mechanic/fabricator/machinist/welder
    http://www.toymods.net/forums/showth...t=tt1uzfe+RA23]
    Default Re: Anyone know what box this is?
    looks kinda like a W50 box?
    rear mount looks different tho.
    early W5x steel case perhaps?
    chuck you are right though, rear mount looks a little weird?
    Jun 2006
    Whakatane
    Rear mounts have been modified as it bolts to a windsor.
    Jun 2006
    Whakatane
    Are they strong?
    W5x's are fairly strong yeah. Steel case ones especially I am told, but I have seen the alloy case ones punished too and they survived.
    Bit of mis-info here.
    In the photo is a steel case celica box (also used in Crown's in the 70's) and is a W50.
    Not as strong as a W5x box (W55, W57, W58), but still strong.
    The box referred to in the above post is the steel sandwich plate W5x box, which is the post ~1988 version, which is stronger than the alloy sandwich plate W5x box (~1981 to 1987)
    ah yes, sorry cruzida, you are correct, i used poor choice of words.
    steel case is w50 = weaker of the w series boxes
    alloy "sandwich" plate W55, W57 & W58 stronger
    and
    steel "sandwich" plate W55, W57 & W58 = strongest in W5x series
    Jun 2006
    Whakatane
    Thanks very much guys this is what i thought. A mate of mine is looking at one to bolt behind a 302 windsor, will be a bit hot so dont think it will be up to it.
    Simon
    Sep 2010
    Hamilton
    Oh is that box still on trademe? I've been looking for a 5 speed for the Crown and that looks like the right vintage.
    GZS55, SA23, AE30, AE70, SE70
    LOL... a hot Windsor, it'll handle it with ease
    Jan 2008
    queensland
    a hot windsor? does it have flames coming off it?
    2009 aurion
    Purple 2000 Hilux - 1UZ
    Jun 2006
    Whakatane
    HAHAHAHAHHAHAHAHAHAHA No sorry im sorry i should use the technical terms shall i? Slightly modified to make a bit more power than standard. If your reply isnt related and constructive to answering the question in thread dont bother replying.
    Simon
    New Zealand
    Apparently the W50 boxes from behind 6 cylinder motors were stronger, had a larger front bearing or similar? Been a fair while since I read that info though, was in an old magazine article. Mate who had a 289 powered 2WD Hilux (maroon one that ended up in Tauranga at one stage) used to smash W50's fairly regularly but he was doing a lot of skids with it so that didn't help.
    Callum
    Yeah, the 4cyl W50 had a ball bearing on the input shaft, where as the 6cyl W50 had a roller bearing.
