Results 1 to 4 of 4
Thread: W58 caseing compatibility (ie A70 W58 for a jza80)
    Slanted Photographer Automotive Encyclopaedia LeaThaL's Avatar
    Aug 2006
    Default W58 caseing compatibility (ie A70 W58 for a jza80)
    hey all
    ive got a NA jza80 at work ATM thats got a buggered w58, im just chasing some info as the customer doesnt have the money to do a reco box swap and were seeing how we can save him some money,
    what im really asking is if i were to purchase a ma70/ga70 W58, will i be able to split the cases and swap the rear so that the ma70 box has the remote shifter setup?
    im still on the hunt for a jza80 remote shifter box but they seem to go fast so im hoping this might be a quick fix
    cheers fellas
    1 G L O V E
    88 Ga70 supra --- Under powered and over cooled Daily
    Default Re: W58 caseing compatibility (ie A70 W58 for a jza80)
    In short it wont bolt up as the jza80 w58 has a larger bearing in the rear housing. I have a jza80 w58 and I needed to get rid of the remote shift so I tried to swap rear housings with a non remote shift (ma70/ga70??) w58 that I have but ended up keeping the jaz80 rear housing and swapping the shift lever top thing over as the bearing was too big.
    Or you could pull the rear bearing off both boxes and also swap those too and it will work but if you are pulling off the bearing it makes sense to get a new one considering the bearing would be off already.
    May 2010
    Stidnam is correct, rear housings are different but any w series can run the remote shifter, you only need to swap the shifter housing, brackets and shift rod and it will work. The other thing to note is the speedo drive in my experience is different between the jza80 and ma/ga70 so best to at least check and swap that over if required.
    Yep, can agree with what the other guys have said.
    You can swap the shifter positions tho
    Wilbo's JZA80
    Wilbo's JZZ12
  1. Washer Jet compatibility
    Last Post: 16-01-2011, 05:15 PM
  2. 1uz/2uz compatibility....
    By joecoolmk2 in forum Tech and Conversions
    Last Post: 13-01-2011, 01:46 PM
  3. 7A rod compatibility?
    By turbo4agte in forum Tech and Conversions
    Last Post: 17-02-2008, 07:03 AM
  4. 1mz and 3vz compatibility
    By The Real Roadrunner in forum Tech and Conversions
    Last Post: 24-07-2007, 06:23 PM
  5. RA60-65 Compatibility
    By AutoXCelica in forum Tech and Conversions
    Last Post: 07-02-2006, 01:24 PM
