Results 1 to 6 of 6
Thread: Diff ID ??
    Junior Member Grease Monkey greg's Avatar
    Jun 2007
    Question Diff ID ??
    I removed this diff from a jzx81 which may not help as the car was also fitted with 2jgte and 154 so may not be original. it has 4.1 ratio,8" ringgear and 3-1 F200 on back plate.would appreciate any help in identifying this as i am trying to put car together in time for nats and have a couple of diff options to consider.
    cheers greg.
    Brum,was going to be a billy cart ,now has motor and 6 speed+++
    1uzfe Mx83
    2jzgte MX83
    Jun 2007
    Default Re: Diff ID ??
    hi, i forgot to mention that the drive axles connect with six studs not four like cressie or JZA70 supra.
    cheers greg.
    1uzfe Mx83
    2jzgte MX83
    It looks like a stock diff, but I dont have enough reference photos to be able to tell if its a LSD or not. Have you tried turning one side shaft to see what the other does? What does the build plate say?
    As for the number of bolts, I have only ever seen a Cressida or JZX81/GX81 or JZA70 have 6 on the side shaft and 4 on the tail shaft - is your donor Cressida different?
    Junior Member Grease Monkey twiztd's Avatar
    Aug 2006
    The 6 bolt means genuine JZX81 and the ratio agrees with that too. Just need to confirm lsd operation or not like zop suggests
    Now - 1988 GX81 Mark II- 7MGTE, GT35R, TiAL 44m, Microtech, 550cc injectors, R154, Xtreme clutch, LSD.... Low boost tune done = 330rwhp@1 BAR...
    Then - 1989 MX83 - The big scrap heap in the sky...
    Jun 2007
    you are right paul the cressida does have six studs but they are spaced further apart and are on a scalloped plate with about 8mm studs .these shafts have a round plate with 12mm studs closer together, the axles that come off them also look heavier. will pop up to stew's place and retreive my verniers! I can"t stop one side by hand will have to get a hand to put some pressure on it.
    Thanks guys greg.
    1uzfe Mx83
    2jzgte MX83
    Jun 2007
    update guys there is a Id number F20SX-C embossed on the side. this makes little sense looking at toyota id codes. axles are not any heavier. it would make sense if it was G294.
    cheers greg.
    1uzfe Mx83
    2jzgte MX83
  1. MX73 Diff Centre in RT142 F372 DIFF
    By Toyocorona in forum Tech and Conversions
    Last Post: 29-09-2009, 05:28 PM
