The cruise ECU has the ability to tell the Engine/Trans ECU to drop out of overdrive if it thinks there is a need... like a big hill...
The engine/trans ECU pin for this is OD1.
Perhaps the transistor in the the Cruise ECU is blown and always ON...
As a temp solution you could try disconnecting the OD1 pin from either the Engine or Cruise ECUs and see if this fixed your problem
Btw you sure it isn't a VZV21?
Wiring diagram for a 90 model that might be the same from the internets...
http://www.playnice.org/pdf/Toyota%2...ual/90_EWD.pdf
