Results 1 to 6 of 6
Thread: 1JZ injectors
    Junior Member Backyard Mechanic HIZOKU's Avatar
    May 2006
    Default 1JZ injectors
    Alright i have done a search and all i keep finding is SARD or Power enterprises injectors
    Does anyone else make injectors for a stock fuel rail? i know denso make both there injectors is there a denso part number for 800cc injectors?
    Or can you mod the stock fuel rail to accept other sort of injectors?
    i have FPR and twin entry modified stock fuel rail now up to searching for injectors and was a bit disappointed to only find the two company selling injectors for the 1JZ non VVTI
    has anyone got other company i can look at for injectors? as if i plan on going E85 in the future i feel like i would be stuck with only 800 being the largest aval bolt in
    [Gentlemen's Club]
    Default Re: 1JZ injectors
    Can you fit a top feed rail with the standard plenum? There is a cheap item on eBay atm.
    MX83 Grande 1jz GT35R buildup here.
    http://www.toymods.net/forums/showth...ghlight=grande
    Some say that his heart has 6 cylinders. All we know, is he's called,
    As said SARD are pretty well the only side feed I know of, but you can always convert to top feed...
    If I was doing it again I'd prbly look at going Injector Dynamics ID725...
    http://www.injectordynamics.com/ID725.html
    Nice and linear
    Wilbo's JZA80
    Wilbo's JZZ12
    wa
    ID's are considerably cheaper than new sards. albiet the added cost of conv to top feed.
    May 2006
    I have asked the question about Ebay ones, and people have had issues with some leaking and so forth and that is why i got a twin entry stock rail.
    Guess im stuck with Sard ones then
    [Gentlemen's Club]
    Jan 2007
    queensland
    might be better to just take it to a competent workshop who specialises in this sorta stuff, especially if you don't want it to leak, or if you just don't trust the quality and fitment of some of the ebay stuff.. this kinda thing needs to be spot on, or they will leak and cause problems..
    see below pics for a Silver top 20V side feed to custom plenum, top feed, turbo conversion using 1000cc injector dynamics injectors (planning E85)
  1. hi imp. injectors and low imp. injectors... problem inside
    By Toy_T-18 in forum Tech and Conversions
    Last Post: 13-12-2010, 09:18 AM
  2. 2jzgte vvti injectors vs RX7 850cc injectors
    By mr75 in forum Tech and Conversions
    Last Post: 22-06-2010, 01:20 PM
