Results 1 to 12 of 12
Thread: Fuel Pressure Gauge
    Junior Member Backyard Mechanic HIZOKU's Avatar
    May 2006
    Default Fuel Pressure Gauge
    This is Prob the most basic and stupid question but i thought i would ask
    Fuel pressure gauge? any real location to have these? as i see some in the engine bay and some in the cabin? does it relay matter where? will in engine bay be fine? or should i put it in the cabin?
    [Gentlemen's Club]
    Aug 2009
    Default Re: Fuel Pressure Gauge
    Unless its got some sort of sender that just sends the signal to the cabin, I would stick with engine bay mounted.
    Project:RA65 with an engineered 1ggte conversion.
    Daily:MA61 - 5me stock auto shitheap.
    May 2006
    This is the kit it self
    [Gentlemen's Club]
    Engine bay for that, best not to have fuel going to the inside of the car!
    Wilbo's JZA80
    Wilbo's JZZ12
    Jun 2006
    Tasmania
    when i had carb set up 4a i had it in engine bay cause you cant get a electronic sender for a low pressure gauge, being mechanical i didnt want fuel inside
    for the jzx81 i have it inside the car because you can get electronic sender units Its reads 0 to 90 psi
    Apr 2008
    that one is defently for the engine bay
    Perth, WA
    The set that shown in your photo (mechanical fuel pressure guage) is definately should stay in engine bay...
    You better get a set of Electronics Fuel pressure guage that can lives safely in your cabin :-)
    Nice to have, but is it really necessary? As far as I am concerned 99.999999>% of vehicles on the planet do not have one fitted. It is after all a diagnostic instrument.
    MS51Crown Coupe,
    fwiw, don't connect a guage directly the rail using aluminum fittings. the vibration will make them crack/fail and you'll have an exciting (and expensive) engine bay fire.
    Apr 2008
    Quote Originally Posted by "Z" UTE View Post
    just necessary for tuning i guess
    May 2006
    for a extra $80 dollers for it, Why not would rather be safe then sorry,
    And i know of many cars with them fitted all big HP cars, what is the point of having a adjustable FPR if you dont know what you are adjusting to? Car it is going on is 300+kw at the wheels and running meth injectors
    [Gentlemen's Club]
    Toyota Farmer Grease Monkey Yotaholic's Avatar
    Feb 2007
    NFLD.
    I use a Cyberdyne electronic FP gauge in my MKIV. It's a cheap alternative and serves it's purpose well as a safe/accurate indash display. I tested it against a handheld shop tester and got the same results with both gauges. One thing I dont like ... The red leds are a little too bright , even with the headlight activated dimmer.
    Mounted in clock location for now.
    82 Ma61 1JZ/R154 HKS Twins
    94 JZA80 V160 S475R (sold)
    94 JZA80 V160 T51R KAI CDN. Spec
  1. Fuel pressure Gauge location
    By merc-blue in forum Tech and Conversions
    Last Post: 25-12-2006, 07:33 PM
