Results 1 to 8 of 8
Thread: Micro tech X4 ingnition box quick wiring question.
    Act
    Default Micro tech X4 ingnition box quick wiring question.
    Hi all
    Started to wire my Microtech into the wagon, First time I've ever wired an ECU. Now I picked up the current 7M with the loom attached so it hasn't been to difficult.
    However I have run into one problem. One wire I can't find an the micro tech diagrams.
    I using these to diagrams
    http://www.microtechefi.com/pdf/LT10SubaruIgn.jpg
    http://www.microtechefi.com/pdf/LT10SFuel.jpg
    The wire I can't find a destination for. Runs straight from the coil packs plug. Its yellow and old mate had it going to a relay.
    Is this ignition to the coils??
    Any help would be great.
    Stitt
    Default Re: Micro tech X4 ingnition box quick wiring question.
    Quote Originally Posted by TheStitt View Post
    The Yellow wire on the 6 pin plug is a coil negative wire.
    Act
    I'd say your spot on, wire is actually orange.
    I plugged it into the coil pack the the coil pack has three wires, 1 from each pack into the male of this plug. So I will earth my mystery connector
    thanks
    Act
    Or are the coil packs like the Injectors, they get a straight power feed and the earth through the ECU??
    I had a second thought and thought this may have been a reason the last guy had the wire off a relay
    from memory the microtechs are negative switching (switch by earthing). its been a while since ive looked at one/wired one up.
    EP82 Starlet GT - [URL="http://www.toymods.org.au/forums/forum-members-rides/71090-stus-ep82-starlet-gt.html"[/URL] SOLD
    EP82 Starlet GT V2.0 - http://www.toymods.org.au/forums/sho...98#post1514198 SOLD
    The IS400, GXE10 with 1UZ - http://www.toymods.org.au/forums/thr...8-StuC-s-IS400
    Coils usually get a +12V Ignition feed on their + terminal and the coil - terminal is switched through the igniter. (or ecu if it has internal igniters).
    Act
    Running a LT10 not to sure Rudi.
    I'll see if I can get some 7MGTE diagrams as the coils still have the factory wiring
    Act
    Just spoke to a good mate who knows Micro tech,
    Wire is 12v ing, ECU switches earths
    thanks all
  1. Micro Tech Question
    By TheStitt in forum Tech and Conversions
    Last Post: 16-03-2009, 10:59 AM
  2. Any moderators about?? - tech log question
    By cptsideways in forum Toymods Car Club Membership and Feedback
    Last Post: 05-07-2008, 03:23 PM
  3. 4age tech question?
    By pro-16t in forum Tech and Conversions
    Last Post: 30-04-2006, 11:42 PM
  4. True Tech Question
    Last Post: 02-04-2006, 05:11 PM
