Results 1 to 4 of 4
Thread: 5MGE Gen1 Engine + 5ME Loom + 5MGE ECU
    West Australia
    Default 5MGE Gen1 Engine + 5ME Loom + 5MGE ECU
    OK so the MA61 im putting this 5MGE into , was originally 5ME.
    The loom that was in the car was 5MGE also along with a 5MGE ECU, which causes issues when connecting to the dash (have to splice things)
    I had a thought, could i put in my donor MA61 5ME loom so that the dash + engine loom is all standard and its plug and play ?
    Or does 5ME loom not connect to the 5MGE engine (water temp / dizzy or something like that ?)
    Please let me know asap!
    Or at least let me know if i can use 5MGE engine + 5ME loom + 5MGE ecu (pinouts are same same)
    Default Re: 5MGE Gen1 Engine + 5ME Loom + 5MGE ECU
    loom is different - ECU does spark control for starters and the dizzi/ignitor setup is different. Also, other things (alt, alt light, dash water temp, etc.) are or are not integrated into the loom.
    West Australia
    Being a 1983 early MA61/5MGE the looms look almost identical and the 5ME loom connects up to the ECU + dash correctly though ?!?
    argh - missed the gen1 bit. If the gen1 5mge has the same dizzi and idle-control setup as the 5ME then it 'should' work. caution: having the same plugs doesn't mean zip if the hardware at the other end is different.
  1. mx73 5mge auto loom diagram?
    By moz rolla in forum Tech and Conversions
    Last Post: 27-07-2009, 11:30 AM
  2. 5mge wiring loom diagram needed
    Last Post: 12-03-2009, 10:09 PM
  3. 5MGE running on 5ME loom and ecu
    Last Post: 01-10-2008, 08:52 AM
