MWP - Need to sort that Rule add in for the new Version. The Notification you quoted has been removed.
Simon
at the very bottom of the page you will need to switch from 'Toymods Basic' style to 'Mobile Style'... style
it should be a drop-down box with those 2 selections in it.
Once on the mobile style site, as Simon said there is a link at the bottom to return to the normal style (a link, not a drop-down)
EDIT: just tried the mobile style on the computer (should still work, I've done it before) but it came back with message that flashed on the screen that said 'error loading page' in a yellow box. It quickly disappeared and was replaced with nothing... just a blank screen.
I needed to back page and re-select the normal style. No idea how it reacts iflose browser and re-open if you accidently changed it to mobile while it's not appearing to be working.
Simon
Beige.... The new Black!!!
Seems to be a bug with the thread icon.
The icon for hot thread with no unread posts has a X in the bottom left hand corner. (the icon for contains no unread posts has no X)
The X is on the closed thread icon.
I was confused for a while there, so many closed threads LOL
Grrr Bugger... Thanks Rudi. That will have to go on the list for later.
Simon
Cheers for fixing the page number Simon, the red really stands out well.
I don't even understand why forums in general have a 'hot thread' ?
Is it based on posts vs time, or just posts?
AFAIK its just posts (ie, goes 'hot' after ten posts or something) which would be 99% of the threads on this forum!
based on number of posts, or thread views, whichever trips the counter first.
Thought so, seems a bit pointless with 15,000 members...
It is some what pointless. But it is one of those default things that no one has ever been bothered changing. Probably a case of it is easier to leave it than to change it.
Simon
Reputation button is still available in non-car threads and.. all section of forum.
this by design?
The Conditionals in the old forum don't work in the new forum (I have tried for hours to find a set that work) And seeing that reputaion is a trigger to permission advancement they have to stay there until I can find a solution.
Simon
CrUZida,
Is the home buttom thing still a problem, I can't replicate it anymore? Browser?
Simon
Still a problem. Using IE7 (work pc)
Click in the white bit (for instance, where you have written ' Cheers Simon ') and home/end/pg up/pg dn do nothing.
Click in the grey sections on the side, they work perfectly.
Also, clicking where the avatar/etc are, it work perfectly.
Its just the post text area.
Yeah, I had the same issue at work (IE7 I think... will need to check) I don't have the issue on IE8, FF3.6, chrome. Not happening on other vb4.1.2 forums though so it is an issue with this board.
Simon
In the top right hand corner it used to show the last date/time that you visited, as I only look at new posts I have no idea how far back to go. Any chance of getting this turned back on ...
