i thought you'd want falling, as the zero crossing point happens at same time regardless of speed? (need to check the voltge goes +ve then -ve.. and if not, swap the wires around)
if one is rising and other is falling, they their relative timing (in degrees) will change with RPM... which could be giving the sync errors?
same cable should be ok.
"either way it doesn't explain how the car would start this morning and idle and run perfectly fine, then later on it won't idle and it won't start unless i crank it for a couple of seconds, then flood clear and it will start."
leaky injector??
also.. are you 200% sure you have the coils firing in the right order??![]()
