so...
if you have the dizzy with no gear in the head, and crank the engine, and spin the dizzt, do you get rpm signal in TS?
it seems odd that both dizzys work fine on a drill, and work when spun by hand, but the only time it doesn't work is when engine is cranking and cam is turning dizzy...
my first thought would be that either the power to MS is having problems when cranking.. either too low, or it is not getting power when the key is turned to "start" as opposed to "IGN"...
second thought is that one of the VR wires in the geared dizzy, is earthing on the body when it is installed? remote chance but...
so yeah, check the MS power during cranking first.
i can't imagine there would be heaps of noise to affect the VR signal during cranking...
hmm, want to borrow a dual trace scope tomorrow??
edit: i'm stoked it starts tooso happy i can piss off the neighbours again
i checked timing again today, marking a "minus 20" point on the crank pulley.
trigger offset is 14deg adn seems spot on.
idle advance is an actual 32deg (idles around 70kpa)!! seems like a lot, but doesn7t like a lot less.... burbles away nicely at around 1100rpm when the fan is on, and 1200-1250 when fan is off....
when i go for blueslip, i might lave the lights on for extra electrical load
and blipping throttle revs so nicelyand i haven7t even started playing with rest of table yet.. just ported the fuel over from MS1, and the timing is all abotu 30deg
