well, for a start, they are not on the money
rockers and shaft and towers will swap.
lifters are DIFFERENT diameter between solids and hydro.
as a consequence, pushrods do not swap.
cam shoudl swap, but some engines have different depth plugs at the end of the cam tunnel, so need to check you have clearance.
you can either lock the lifters solid (heavy), or get ones from something else (some holder thing or other can be used apparently)
if you are going sides, then twin will be a whole lot better (more even mixture distribution, rather than the pulsing that will happen), and easier to find manifold fori am close to purchasing a single 42DCOE weber and am wondering if I'm going to lose power and will it be a worthwhile swap
i have a camtech 609, and it probably has the power range you are looking for perhaps... thats a 275/284 solid cam with 435thou lift and abotu 230-235@50thouideally i am looking for a motor happy to sing to 7 occasional 8thou rpm, lightened flywheel, freeflowing extractors, 2" open exhaust
i just need to decide cam, induction and lifter spec. i will be getting the dizzy recurved to suit the cam.
the head has been skimmed 30thou, and i have no idea of compression ratio until i cc the slugs in the motor.
any help would be fantastic. i can only take so much info from cam grinders/engine rebuilders until i get real corolla driver info
cheers adam
you might need to check valve clearance to pistons, to see what lift will be safe, but shouldn't be a big problem, although the 5K chambers are thin compared to 4K.
induction.. why not go EFI?plus a megasquirt, and control fuel and ignition
if you go sidedraught, you will need to choke them down to make it drivable anyway, but EFI = no chokes![]()
