Results 1 to 2 of 2
Thread: AE86 Castor Rod fit RA28?
    Junior Member Backyard Mechanic Bazooka's Avatar
    May 2006
    Default AE86 Castor Rod fit RA28?
    Does anyone know if the AE86 castor rod will fit an RA28?
    As I'm converting to rack and pinion steering using the AE86 crossmember the lower control arm mounts are now much further outboard. I did not get the AE86 lower control arms with the rest of the stuff and may look at modifying the Celica ones to adjustable to make fit.
    Now that everrything else is adjustable on the car I was thinking of using an adjustable castor rod too. I just need to know if the AE86 rod will fit the RA28 lower control arm?
    Default Re: AE86 Castor Rod fit RA28?
    Or use KE70?
  1. AE86 vs RA40 hub and strut measurements --- HELP
    Last Post: 26-10-2009, 01:04 AM
