Results 1 to 2 of 2
Thread: 1GGZE into GX71 wiring problems
    Wairarapa
    Default 1GGZE into GX71 wiring problems
    Hey guys
    I've got a 1ggze in a GX71 Mark II but have a few issues
    Firstly, the ISCV is wired into the ECU fine, but there is another wire (yellow w/ blue trace) which has been cut - where does this go? There is no noise coming from the ISCV at all and it is open all the time (idles high)
    http://img17.imageshack.us/img17/4665/dscf5899d.jpg
    Secondly, the tacho doesn't work - What I want to do is splice the yellow wire from the ECU and run it to the factory tacho. Problem is I have no idea where to run the wire for the tacho signal as I can't seem to find a GX71 wiring diagram
    Thanks in advance.
    Toymods Club Member Backyard Mechanic auto351's Avatar
    Nov 2007
    N.S.W
    Default Re: 1GGZE into GX71 wiring problems
    Have you seen these drawings ?
    http://www.supra.co.nz/1g.htm
    that wire from the ISCV (yellow w/Blue trace) connects to switched power from the Main EFI relay.
    This is for the GTE but what your looking for should be the same
  1. ECU pinouts Gen 3 1GGZE (Definitive?)
    By infotechplus in forum Engine & Driveline Conversions
    Last Post: 24-09-2017, 10:29 PM
  2. Rn110 hilux 1GGZE conversion
    By Bullfrog in forum Engine & Driveline Conversions
    Last Post: 15-02-2009, 08:17 PM
  3. Clock wiring problems
    By anty109 in forum Tech and Conversions
    Last Post: 20-01-2009, 04:49 PM
  4. AE101 4AGZE wiring
    By clemmie in forum Tech and Conversions
    Last Post: 18-10-2007, 12:31 PM
  5. 4agte wiring
    By pro-16t in forum Tech and Conversions
    Last Post: 25-08-2007, 10:04 AM
