im assuming you mean conversion into a celica given that you wanna change the sump
hah! grouding the engine! fuck i havent done that in my celica yet..
in terms of the clutch it depends on the version of 1g, there is a 9" gen1/2 and 9.5" gen 3. youre right tho that there is no probs using that gearbox.. youre only real concern is that the friction plate splines match the box and the diameter fit inside the pressure plate. the pressure plate dowels will need to suit the flywheel..
depending on what the x-member in the celica you have have will depend on which sump you need
to mount the engine in mine i used a rear sump 1g and didnt have to change anything but massage the rear sump for the steering arm
you will need 1gge (non turbo) metal engine mounts to replace the cast items so your oil drain can be plugged in
EDIT: oh yeah and the best place to look for this stuff is in people thread in the members rides section
