Results 1 to 8 of 8
Thread: MX83 odometer works, speedo doesn't
    Mar 2008
    Default MX83 odometer works, speedo doesn't
    Trying to finish off the 1JZ conversion in my S2 MX83. Have just hooked up the speedo sensor but only the odometer is working. The speedo needle doesn't budge. Anyone have any ideas?
    Jan 2011
    Default Re: MX83 odometer works, speedo doesn't
    Have you checked not loose wires/connections?
    You could just try another cluster to determine if the problem is in the cluster or elsewhere.
    Mar 2008
    up to posting this thread I hadn't taken the car for a drive of more than a couple of hundred metres. I've since taken it for a better drive and after a couple of minutes the speedo kicked into action. obviously it's deterioration of either the circuit board, caps, or both.
    Apr 2008
    i thought it was cable?
    Mar 2008
    Only S1. The S2 are electronic
    Apr 2008
    well there you go...did not know that!
    Jan 2011
    Are you still having the same problems or has it gone away?
    Mar 2008
    I took the car for another run up the street today and it seems to be okay
  1. Speedo error... is it linked to the odometer?
    By Slim in forum Tech and Conversions
    Last Post: 20-05-2010, 09:38 AM
  2. Guide: Removing paint from plastic parts (more input needed)
    Last Post: 13-04-2006, 01:09 PM
  3. you can light up your speedo with LEDS
    By puzzle man in forum Tech and Conversions
    Last Post: 21-03-2006, 10:34 AM
