no, this is in a 4age mind you. i just tapped into the water outlet on the rear of the head.
generic photo of rear water outlet
600 Club Member: Toymods Large Member
MegaP00 - 7MGTE Skunkworks division
RIP - Nathan Dean (TA-022)
4agte Sprinter - 11.7 @118mph WSID
2.45 @ mount panorama
1.56 @ eastern creek, 1.10 @ wakefield
1.24 @ oran park GP
2.00 @ Phillip Island
Would I be right in the wagon as the top of the rad is higher than then the head??
without spending lots of money on development:
- play around with the cooling bypass circuits (that goes to the turbo housing, throttle body, cabin heater, etc) by changing/reducing pipe diameter
- breather tank at highest point in engine bay (could be tricky) which feeds radiator top tank
- consider a falcon (EA-ish era) radiator fill tank as a combined breather/fill tank
- widest radiator possible
- significant tank capacity (above & below radiator core)
- ducting to radiator core & engine bay tray
- shrouded fans
- anti-boil only for summer
- chemical flush of coolant galleries in motor
spending money:
- analyse the 7M head cross sections posted by andrew_mx83
- drill thru to coolant passages and feed them to the breather tank (test on dummy head first, size of water ports would require some thought)
- other suggestions above as required
this may not end well as it would seriously change the coolant flow thru and around the thermostat.
fwiw: a while ago I was talking to Crag Aggio (owner of the replica TA64 up here in Qld) about cars-n-shit-n-turbos. He mentioned that he found the excel alloy radiator (plus thermo fans) did a better job of bringing down high coolant temps in his rally car than a thicker 3-core radiator. This is for a car that might be under high engine loads at fairly low road speeds. It has a substantial FMIC core up-stream of the radiator. His theory was that as the air passed thru the radiator core it heated up so the rear-most vertical cores had poor heat rejection to the now quite hot air-stream.
His solution was the wide mouth radiator (aka the excel alloy jobs) which from memory are 30-35mm thick? (feel free to correct this), plus some ducting at the front plus cold air induction.
I know this forum has had previous threads discussing radiator core efficiency (sorry, havn't searched for them) and this runs counter to the arguments in them, but it's a real world example of improving heat rejection from the cooling system.
off the wall suggestion: reduce intake air temps with water or water+methanol injection?
this is exacty what im doing atm. do you still have the heater core connected in the car? i know i just bypassed mine, but now im thinking this is causing excessive coolant to be re-circulated into the engine without going into the radiator (not sure what the 7m setup looks like but thats how a 4a works) so im thinking with the removal of the heater core this needs a restrictor to work as factory designed.
1.24 @ oran park GP
i also read an interesting article about subaru cavitation problems that was eventually traced to the bottom inlet pipe simply not being large enough to supply the water pump with suficent flow at rpm, this caused cavitation, thus causing bubbles in coolant and the engine running hot.
1.24 @ oran park GP
inneresting..
Glennn, have you checked the type of impeller in the water pump? massaged it for non-cavitation goodness? considered pump speed etc? coolant additives to change vapour pressure/surface tension?
link for the above article http://www.mrtperformance.com.au/res...boiling-theirs
1.24 @ oran park GP
Yeah, understand the general concept of why one is used, more wondering if there was any known problem with the 7M trapping air, or Glen's car specifically.
Glen: Did you find that this was the problem leading to your head troubles, or suspected, or just trying to eliminate any chance of shit going south again in general?
Very interesting article, might need to measure the size of the the pump inlet!
Stew - standard but new water pump, haven't tested anything.
Box - old engine developed alot of air in the cooling system and was forever blowing out of the overflow. Trying to address this straight up this time.
the O-D of the pump inlet is 35mm So subtract wall thickness for ID
I just built one of these for a 351 supercharged corolla burn out car and worked a treat,enables you to put a non standard rad on there that can be bigger as you are not as restricted with having to replicate the original exactly. It's a shit load easier to bleed and eliminates any chance of air trapping in the head as you can generally run it nice and high on the strut tower.
-Just Alloy Radiators-
www.alloyradiators.com.au
Also seeing its a 7m is suggest you get some of my coolant which cannot boil,just incase.![]()
