Results 1 to 6 of 6
Thread: Problem with dashboard lights in 96 starlet. Please help
    Magical Mushroom Grease Monkey Willy's Avatar
    New South Wales
    Default Problem with dashboard lights in 96 starlet. Please help
    Hi Guys,
    I put a stereo head unit in for my sister in her 96 starlet, I've done a ton of them and never had a problem with the wiring.
    When I pulled out the original stereo I tested the wiring into the back of the original plug.
    Other than the speaker wires i had;
    12V + connected to ignition.
    Ground wire
    2 x 1V continuous power which didnt turn out to be high enough voltage to start the stereo, one was Blue with Yellow trace, the second was brown.
    Because the 1V wires werent high enough voltage to start the unit up, I instead spliced into a continuous 12V + wire that was connected to the hazard light switch.
    Unit started up no problems, but now no dashboard lights. I have all of the warning lights or "reds" and the blinker arrows still light up, but the lights behind the dials, and the interior light are not working.
    I checked all of the fuses, including the "gauge" fuse which was fine, tested for power at the light dimmer switch but there was not any power there.
    Any ideas or help would be appreciated.
    I did try to connect those Blue and brown wires that I wasnt using, but still nothing.
    Relax, i'm with goatse...
    Default Re: Problem with dashboard lights in 96 starlet. Please help
    do you have tail lights?
    Junior Member Grease Monkey TRD-12A's Avatar
    Nov 2009
    sounds like youve blow a fuse because you have tapped the earth wire into the tail light circuit i see it all the time cause when the taillights are off there is an earth and everyone sees this and thinks its an earth common mistake
    New South Wales
    No tail lights, will check the fuse and my wiring this afternoon. So the tail light circuit runs into the stereo loom, thats just odd.
    New South Wales
    Ok so the fuse is blown, put in a new one, turned the lights on and it blew again. So I'll have to pull the stereo out and try to identify which one is for the tail lights.
    Nov 2009
    itll be the wire you used for earth guaranteed all genuine headdecks have a taillight feed to it to dim the headunit down when the lights are on
  1. Ke20 headlight problem.
    By maurice c in forum Tech and Conversions
    Last Post: 20-12-2008, 09:20 PM
  2. Corolla Brake lights stay on
    By 13BTTA22 in forum Tech and Conversions
    Last Post: 17-09-2008, 06:40 PM
