Results 1 to 15 of 15
Thread: toyota hilux 1996 EXTRA CAB more power please
    Aug 2006
    Exclamation toyota hilux 1996 EXTRA CAB more power please
    hi there
    I have an toyota hilux 1996 EXTRA CAB 2.4 petrol 2 wheel drive and it really lacks any power... what can i do to make it go properly?
    Default Re: toyota hilux 1996 EXTRA CAB more power please
    You mean it has less power than it should and want to fix it?
    Or do you mean you want more power than the 2.4L is capable of?
    Aug 2006
    sorry my mistake.....
    its functionally as it should but the 2.4 is just not enough.... its an auto also .....
    22rc or 22re?? if 22re supercharger kit/turbo kit?? 1jzgte/w58 is a good option,
    Aug 2006
    Quote Originally Posted by lilcrash View Post
    Its an RN 90 R says 22R on the plate.... so what options does this give me??
    May 2010
    What budget do you have is the first thing? If you are willing to spend in the thousands then go the 1uzfe. Best power vs expense vs reliability IMO. Literally a pile of options though just comes down to budget really.
    You easiest/cheapest options will be 1uzfe, 1jzgte. 3rzfe, 5vzfe. Anything is possible just a matter of money
    Jan 2008
    queensland
    make sure it is tuned properly first - the cheapest option is to slap a weber carb on it and stick a set of extractors onto the standard exhaust. use good fuel and you could bump up the timing a couple of degrees.
    but then still stick the 1uzfe in it
    neil
    2009 aurion
    Purple 2000 Hilux - 1UZ
    wa
    This works ok for my daily hilux,goes ok for what i need it for i still have to tidy up a few things and sort the A/C
    Aug 2006
    can you tell me more about these options and build prices etc??
    need to get it done in melb also
    ta
    Jun 2006
    Are you a P plater? if so, no engine mods or swaps allowed.
    If you want more power on a budget, look into a Commodore V6 conversion. whole cars can be picked up for not a lot of money. will be cheaper than just about any Toyota engine swap that is worth doing. (IE 1J -2J I6 or 1UZ V8) .
    Ultimately a 1J or 1UZ would probably be faster, but if you just want something that goes ok, the VN/P engine is hard to go past.
    Aug 2006
    No im well over 18.......................... dont want vp /vn engine..............
    i always want the best..who does it here?
    did you want to keep it auto?? i will point out the upsides and down sides that i can see with each motor
    - 1uz is probably best bang for buck / 8cyl rego
    - 3rz keep 4 cyl rego / not sure whats involved in the swap
    - 5vz nice torque reasonable power / not sure whats involved in the swap
    - 1jz/2jz really good in a straight line / cant drive around corners quickly or in the rain
    Aug 2006
    yes i would like to keep it auto.... doesnt have to be a flat out in a sraight line want it to turn corners...
    who does these here in melb?
    Jan 2008
    queensland
    1uz all the way
    make your own mounts
    crown headers make the exhaust fit easy but dont flow terribly well - extractors are about $1200
    exhaust 500 - 1000
    tailshaft 350 - 500
    wiring 750 -1000 if you cant do it yourself
    front cut 1500 - 2500
    ++++++ work out your budget and then double it
    htfu and do it yourself
    2009 aurion
