Results 1 to 15 of 16
Thread: Engine just lost compression
    Oct 2009
    Default Engine just lost compression
    Have been working on just standard 2t engine, cultch and gearbox transplant after son smashed his TA22. I just started with the radiator not conneccted for 30 secs and lost all compression.
    I gather I have stuffed it anyone know which end would have gone top or bottom.
    Will pull head off tomorrow a bit distrought with all the work I have put in not sure what I am going to do.
    Low rep 1st year Apprentice
    Aug 2010
    Default Re: Engine just lost compression
    Cam Timing?
    Oct 2009
    No it was running smooth the heat from not having any water has blown something I gather.
    I just wanted to make sure it was running before putting in the radiator
    Aug 2010
    30 seconds will not likley cause overheating.
    I would look at the basics first.
    wa
    yeh, wouldn't overheat in 30secs, if it didn't have oil then yes you'd stuff it.
    Oct 2009
    No Oil is fine maybe 60 secs not sure
    for reference ive driven almost 20 mins without a water pump. it wont be a water issue
    May 2010
    You should really check compression with a gauge and see if it is a particular cylinder or the whole engine before pulling the head off. It can be hard to find small type failures if you don't know where to look.
    As said above takes quite a while to overheat an engine even without water so that won't be your issue
    Apr 2007
    As has been said do some checks first, what makes you think that you have " lost all compression" ...
    Oct 2009
    Just turning with the sarter motor I can tell by the sound (Like turning over with no plugs in) and and pull around by the fan with no resistance. I will have a better look in the morning.
    Thanks all
    Pop the oil filler cap and check if the cam is turning..
    Oct 2009
    As I said before no compression and cam all working I have not touched this angine as was a 50 k 2T that came with the car as a spare.
    Have removed the head and all looks good but a lot of big carbon particle's that I gather have interfered with the closing of the valves. So I will de carbon and have a close look at the head and remove valve and lap the valves and check valve guids and seals.
    Question !! do thses 2 T heads have problem with cracks?
    Oct 2009
    On closer inspection it seems that, because engine has been sitting for year, the head gasget went a little rusty around the bore and seperated and I think that is were the compression was lost. The bore still has hone marks and no lip at the top that I can feel.
    Oct 2009
    Buying some gasgets but unsure of engine year
    It is a 2 T. 1243485 is engine number. So pre 09/75 or post. I am head gasket valve seal and inlet gasket .
    I am at supercheap now ordering if anyone knows the answer
    Oct 2009
    sorry guys but I have more questions about my engine.
    This engine has hi top pistons so would that make it a post 1975 manufacture?
    I need to order some gaskets and I am unsure of the year of manufacture. As I have said not the orig motor.
    Hope someone can help?
    Thanks in advance
  1. Sams MA61 7MGTE Conversion Guide
    Last Post: 08-07-2015, 12:12 AM
  2. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 07:27 PM
  3. No compression at all, apparantley
    By Chrisso in forum Tech and Conversions
    Last Post: 05-04-2009, 03:46 PM
  4. MA70 --> JZA70 Conversion
  5. 3SGTE Engine rebuild; What compression ratio to go with.
    Last Post: 13-05-2007, 11:48 AM
