Do you want to do that for wheel clearance or looks?
[ $[ $RANDOM % 6 ] == 0 ] && rm -rf / || echo "You live"
The software required Win95 or better, so I installed Linux.
4AGZE into TA22 http://www.toymods.net/forums/showthread.php?t=16775
1JZ powered RA60 https://www.toymods.org.au/forums/th...light=1jz+ra60
Daily: Toyota '05 Rav4 Sport
I would think it not an issue at all, as its just a logo isnt it .. I would personally file it as its more controllable, make sure you dont leave any deep marks in the surface ..
My mistake, certainly looks like a logo though ..
Don't know why the port isn't more internal ...
+2 for fluid bridge
series 5 calipers are the same mounting points and dimensions I believe but
squeeze cast and differently shaped, they have a long fluid bridge with a big mazda
logo cast over it, the mazda letters can be ground off just not the bridge section but
its a lot better looking in my opinion...
I'm not removing for looks, I need the clearance on my SSR's. My Performance Challengers aren't going to fit without at least 20mm of spacer. It looks like I'll need spacers and longer wheel studs no matter what I do
Oh well, thanks all, that could have been a damn expensive mistake![]()
Hahah, I should have clarified.
I've already got 25mm bolt on spacers, but 15x8 -8s stick out past the edge of the guard with the bolt on spacers.
I also have 6-7mm slip on spacers, and I required 3 of these for the Performance Challengers to clear the calipers. My SSRs only just hit the caliper, but loosing 6mm of thread leaves me without enough wheel stud length. Either way I'm![]()
You can get 15 and 20mm bolt on spacers too.
you can get wheels that might fit too
jk, do what you like![]()
what about dirty nissan wheels?
Wrong offset Stew. I have the same problem on my race car,
Caliper sits 25mm proud of the front of the disc. Also pictured there is the solution to my problems.
