Results 1 to 7 of 7
Thread: ** Frame Fracture .... Steering arm? **
    Junior Member Grease Monkey toylica's Avatar
    Oct 2008
    Default ** Frame Fracture .... Steering arm? **
    Hey there,
    I have noticed there is alot of play in my steering in my RA23 Celica, so i grabbed an innocent passer by to turn the steering wheel while i try and locate the source of the play. Upon inspection i noticed when the steering wheel is turned and you look in behind the wheel.... it seems that where the steering arm pivot is bolted from the other side .... there is a section of metal that flexes excessivly? ... is this a common problem? i was told by a local mechanic it was?
    Anyone know of a welder in brisbane/sunnycoast that would sort it?
    Aug 2009
    Default Re: ** Frame Fracture .... Steering arm? **
    what type of pivot is it.. its not a uni joint is it?...
    anychance you could take pictures?.. im sure with pictures youll be inundated with clever ideas and solutions to fix your problem
    Oct 2008
    Hey, i will take photos when i get to the car again.
    I dont really know much about car steering/suspension but i just googled it ... I beliee it is the pitman arm
    Aug 2009
    like i said buddy a picture speaks a thousand words.. But yes pitman arms usually have a splined end where they bolt onto the sector shaft of the steering box and a tapered end where they bolt onto a drag link arm or some sort of steering linkage and its usually the tapered end that gets loose and flogs out..
    This always happened to mine and welded it up a few times. Rack n pinion fixed it in the end. But if not going down that path you need to do some reinforcing.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    Junior Member Grease Monkey KENut's Avatar
    Jun 2009
    ^What he said. Flex there is a common problem with this type of steering, so reinforce it or convert to rack n peanut
    Oct 2008
    thanks guys
    how much did the welding cost you?
  1. Steering box woes, ke26
    By vkboy in forum Tech and Conversions
    Last Post: 22-11-2009, 07:02 PM
  2. Bump Steer!
    Last Post: 19-07-2006, 07:16 PM
  3. RA2x steering box tech Q's
    By Gleno28 in forum Tech and Conversions
    Last Post: 04-07-2006, 11:17 PM
