it is tru the 2jz-gte engines can be modified to have the turbochargers modified to work in parallel, and on stock boost they do kick later and really arent that impressive behind an automatic transmission..
there is no "turbo vehicle" examiners, tho if you wish to have a pre purchase inspection i can do it for you, but you will find if you want shaft play examined, it would have to be authorised with the seller, for me to pull all the intake pipes off and inspect the turbos (which is a pritty time consuming job) which of course would have to be paid for seperately..
what you need to find is another vehicle that is set up parallel, and compare the 2..
) They are doing a full 100 point safety check and checking the turbos (compression test, etc). In the worst case scenario that the turbos are stuffed, do you know where I can pick up some replacements? A link would be great
