Results 1 to 7 of 7
Thread: weird wiring issue, reverse lights.
    wa
    Default weird wiring issue, reverse lights.
    my reverse lights aren't working. here's what i've chaecked/tried so far. (st185 gt4)
    bulbs: fine not blown etc
    switch: when in neutral/ign on receives 12v sends nothing. when in reverse ign on/eng off opens and sends 12v, (checked with mutliM)
    hooked up a little circuit test light (the pen type with a fuse and aligator clip for earth)and it light's up when i put it in reverse.
    but an actual bulb that i have in a tail light bulb holder with wires coming out doesn't light up? yet it will if i have the two wire from the bulb holder goin straight from the battery positive/neg????
    WTF? tail/reverse lights just need 12v and ground don't they?
    Not known unless ur blown Backyard Mechanic
    May 2007
    Default Re: weird wiring issue, reverse lights.
    its not a twin filament globe in a single filament slot is it?...
    wa
    nah, single.
    Fear the Rapeodile Carport Converter blakeg's Avatar
    May 2006
    they are negatively switched. try disconnecting the switch on the box and bridging it out with some wire and see if they come on with the ign on. .
    the switch on my box failed and gave the same symptoms .
    Junior Member Grease Monkey TRD-12A's Avatar
    Nov 2009
    Check for power and earth at the socket that way you can see whats happening if it is the box like blakeg said you should be getting 2 power signals one with ignition on and then one when in reverse
    wa
    ok so i disconnected the plug and bridged the wires and the rev lights came on with car ign on and in rev, but won't if i plug it back into the gearbox switch.
    so does that mean both switches i have are faulty? i think i have another switch i can try, could it be the internal mechanism that is supposed to engage the switch? that'd be a nightmare.........
    wa
    never mind. got it sorted. it was actually the plug being rooted, wasn't holding the pins tight so when you push the plug on it was only ever so slightly pushing the wires out and not connecting properly.
    yay, only the engine and gearbox to clean of oil and grease then back to the DPI for registering........
    thanks guys
  1. MA61/MZ11 Reverse lights
    Last Post: 21-01-2010, 10:24 AM
  2. TA22 Wiring Harness
    Last Post: 16-11-2009, 12:48 PM
  3. Replies: 5
    Last Post: 03-05-2007, 06:39 PM
  4. ST162 Starter Motor Wiring Issue
    Last Post: 27-12-2006, 04:39 AM
  5. Wiring issue? - temp gauge stuck on max
    Last Post: 18-02-2006, 03:49 PM
