From my experience 4a s will mostly blow between cyl no.2 and 3 cause of the gasket thickness there is quite thin between the bores and with extra boost it can simply push the gasket out.
On my motor i also have probs with it going at the back of cyl 4. This seems to be the most common place on mine not sure why mabe to do with a hot spot?
I have instaled a water bleed there to get rid of all the air from the back of head when bleeding coolant
AnywayI would suggest a steel item like a HKS one next they are very Gutsy gaskets.![]()
