first modification. remove 2sc and place in bin.
in a few ways not the most awesome base to start from. as you have a crud motor, crud box, and crud diff.
brakes/susy. maybe ma61 struts could fit? or mx83 if you want 5 stud haha.
in general....
cheap modification = illegal or not worthwhile
				 St141 Corona Cheap Mods Ideas?
 I got idea this while working as a refrigeration apprentice. If cooling the air makes it denser than cooling the fuel should work right then? Yep it sure does! haha OK flame me now peeps! Get some 1/8 flex copper and some two inch steel pipe. Slowly and carefully work the copper around the pipe to make a tight copper coil around the pipe. Then encase the coil in 3 or 4 inch PVC and insulate. I used rubber refrigeration insulation and mount it in line as close to your fuel pump as possible. Take the steel pipe or similar and weld a bottom on it, fill with salt and water to lower its freezing point, and chuck it in the freezer. Then when you want to go drifting drop your steel pipe in add a little water and you will be surprised at the difference. The more coils you have the more effect it has, as the fuel is moving through the lines so quickly this makes a huge difference. You will espically notice the affects if the car idles between corners...
