it is made of p00, obviously.
Steve
i couldnt quite tell you... could possibly be nylon which some series 2 rb25dets have..
the back side is ceramic as you probably know.
try to find out 4 you..
Ian
"If you can see Chuck Norris, he can see you. If you can't see
Chuck Norris you may be only seconds away from death."
too right Karl
this is why no more than 12 psi stock... even that sometimes is pushing it...
I reckon I'll be changing that compressor wheel!
I don't mind so much if part of the turbo (ceramic turbine) flies out the exhaust, but I think having it go into the engine would be not-so-good.
(\__/)
(")_(")
you could just use a better turbo?
Yeah, I found a buyer for it and for the steam pipe manifold to suit it.
He's a well respected tuner and 18RG owner is checking out the specs some of the Garret range for me.
Seeing as the engine won't be doing heaps of revs, most likely a T28, he's checking turbine/housings that are available as that engine is a bit of an odd combination.
Start boost around 2000RPM, 1 bar boost around 3000RPM and hold to redline sounds ok to me, what do you reckon?
(\__/)
(")_(")
just something i come across today
found on a Finnish (country) website
hello
check this car out.....
It's Clancey's old wagon.
http://forums.toymods.org.au/index.p...6d6a2d8b06355c
Here are some specs of my little turbo corona wagon Smile
RT118 Toyota Corona Wagon
18RGEU (Approx 7.5:1 compression)
Accessories:
- Standard head
- Standard internals With O-ringed block
- 2mm copper head gasket
- Standard cams
- Standard 18RGEU intake with 2.5" throttle body
- Series 4 RX-7 550cc injectors
- Custom made crank angle sensor (based on a Toyota 3S-GE item)
- Quad Bosch coils
- T3 turbo (RB30) with factory actuator & internal wastegate
- K&N air filter
- Custom made turbo manifold
- Custom made intercooling piping
- Pulsar GTi-R intercooler
- AVO blow-off valve
- 3 Core radiator
Engine Management:
- Microtech MTX-8
- 2-stage electronic boost controller (8 or 16psi normally Smile)
EFI Extras:
- Surge tank
- Low pressure fuel pump
- Added return line to tank
- Camira EFI fuel pump
Exhaust:
- 3" dump off the turbo
- 3" high flow cat
- 3" mandrel bent exhaust
- Straight through muffler.
Driveline:
- Clutch: Custom 1600 pound pressure plate with 4 puck clutch plate
- Rebuilt Celica steel case 5-speed
- Standard Borg Warner diff
Brakes:
- Standard discs with Sumitomo 2-Spot calipers front (Bendix pads)
- Standard drums rear
Suspension:
- Front:
- King springs with Koni adjustable shocks
- K-Mac Swaybar/ Urethane bushes
- Rear:
- Reset height original leaf springs with an additional spring and Koni adjustable shocks
- Urethane bushes
Rolling Stock:
- 14x6" Datsun 200B-SX rims
- 195/65-R14 Goodyear Eagle Ventura tyres.
Bodywork and Paint:
- Ford Quicksilver paint
- Custom rolled guards (where are my pliers again?).
Interior Gadgetry:
- Microtech handset
- Later model Toyota bucket seats
- Autotecnica wheel
- Autometer boost gauge.
Stereo Gear:
- Rockford Fosgate front load CD-Player
- Rockford Fosgate 8-stack CD-player
- Alpine 6" splits (front)
- Jaycar Response 6x9s (rear)
- 2 x Kicker 10" subs
- Two Jaycar amps with more wiring and filtration gear than you could poke a stick at
Future Mods:
- Front brake upgrade
- Cold air induction
- In-dash tacho
- LSD disc brake rear end
- Rust repair and paint respray
Ok, just an update on the 2.4 litre build. Some previous details weren't quite on the money so hopefully this should clear up exactly what was done
The 22R crank has no offset grinding. As the 22R rods are narrower than the 18R rods (along the crank axis), the big-end journals were all opened out (made wider along the crank axis) a little. The 18R rods were side ground. We settled somewhere between the 22R and 18R rod widths where we took the minimum amount of material from the crank throw while still being able to move the rods 2 & 3 outward (toward the ends of the crank) in order to clear the centre web of the 18R block. The small-end of rods 2 & 3 sits about 1mm offset toward the centre web, once again, to avoid taking too much meat from the crank.
Hope that helps
OK update...i have pics of the 18RGT exhaust manifold, should be here tomorrow morning, stay tuned.
As promised
and two more
Looks nice Justen.... you should be able to flog off a few of those
... if not here, then Ebay motors
All this talkl of 18R-G turbos makes me want to hurry the fudge up and bolt some turbo bits onto my engine now!!
Justen,
What turbo flange are they made to suit?
Are you making more than one? If so how much would you be selling them for?
ace
That is a twin entry T3 flange but the idea was the manifold would be suitable for the more common T25 flange and an internal gate turbo as well.
I'll have pics of the setup on the car by Mon so you will be able to see how much room this setup leaves you with.
Price is around the $500 mark....really depends how many get made at once as i can bulk order bits. Internally gated manifolds would be the cheaper of the 2 obviously.
I have already sold all of the 1st lot of flanges that were made.
