Results 16 to 24 of 24
Thread: Injector wire size??
    Default Re: Injector wire size??
    Rhyno - definately OD as i'm also using a couple of 6mm OD (50amp) with fusible links for power circuits to the fuse panel.
    I can beleive the extra weight will be a factor with a light car.
    Cheers gents
    weight for one wire wouldn't be an issue, but for a whole chassis+engine loom, if you can remove several kilos of wire & insulation then it can contribute (as part of a larger weight reduction scheme) to vehicle performance.
    Junior Member Backyard Mechanic Rhyno's Avatar
    Jan 2010
    NT
    hks7mgt - You should be sweet then.
    thechuckster - Excatly where I was coming from, it all adds up in the game of speed
    Happy Days
    Aug 2010
    Rhyno, when you talk about cable size you should refer to it in mm2 (gauge). OD or ID doesn't mean much as OD could be referring to a lot of plastic sheathing and ID is very hard to measure. Also when they spec in cables for automotive wiring they used use a gauge that will hold up to the fuse ratings. e.g. If you use a 0.5mm2 you would use a 10A fuse or less. I've listed below some of the common wire sizes and their currents (at 40 degrees temperature):
    0.3mm2 = 8A
    0.5mm2 = 11A
    0.85mm2 = 14A
    1.25mm2 = 19A
    2mm2 = 26A
    In regards to temperature de-rating:
    You can use this list as a rule of thumb:
    50C 0.88 * rated current
    60C 0.75 * rated current
    70C 0.58 * rated current
    80C 0.33 * rated current
    In you application (injector) I would use 0.5mm2 which allows for 4 amps at 80 degrees C
    Fast, Cheap, Reliable
    You can only ever have two..
    That information is handy thanks.
    But, i've never heard of a wire rated in that way. Would it be wrong for me to ask would a 0.5mm2 cable be equivilant to in say a 2.5mm or 4mm cable (OD) approx of course (taking in your comment above that some plastic sheilds could be thicker than others)?
    I went into the auto electrical place (a good one) and paid for the wire they use. It was rated in the current it can handle and it just worked out that 4mm OD was 15A and 6mm OD was 50A. I'd assume 0.5mm2 is the 2.5mm OD (or what is commonly one size smaller than the 4mm).
    I'm just personally interested now as all my wirings is done.
    afaik, wires are always rated in that way.. mm^2 of conductor
    in fact, the mm^2 is often printed ON the insulation
    the other way is in "gauge" liek this
    http://www.dansdata.com/images/io030/wire640.jpg
    check otu this table. http://www.engineeringtoolbox.com/aw...uge-d_731.html
    has amrican wire gauge (AWG) vs diameter vs mm^2 (cross-sectional area)
    eg 0.52mm^2 = 0.81mm diameter (of copper) = 20AWG
    but then you have multistrand, which is labelled differently, like 24 x 0.2 = 24 strands of 0.2mm diameter
    i never looked so far into cables before. I can understand how different they all are and therefore a need for a standard and for professionals in the industry to be able to follow those standards accordingly.
    I first took some home electrical cable (you know the green, black and red in the single white sheild) for use for my car, but later learnt it was not suitable for auto-electrical use (althought it may have worked) as there were less strans for the similar cross section which would be harder to bend, harder to solder and just not auto-electrical cabling.
    did i make the right move here?
    Aug 2010
    Home electrical wire wouldn't be the best wire for automotive wiring, mainly due to it's temperature rating. It may be rated to 10A but that would be at temperatures less than 40 degrees C. So not using home electrical wiring was the right move.
    Auto cable is funny.
    Yes, the right way to measure is in mm^2 (cross sectional area). That's the only real way to understand how much conducter is in the wire.
    Simple explanation of AWG (gauge) is that it's just a non-metric scale for mm^2 (cross sectional area).
    As is always the case, some 'tard goes and screws thing up by introducing a non-standard way of measuring auto cable. Hence, people refer to it as 2mm, 3mm, 4mm, 5mm etc cable.
    A reputable auto elec would only call cable Xmm if it was essentially what people understand Xmm auto cable to be.. ie: 4mm ~= 1.85mm^2, 5mm ~= 2.9mm^2
    I have seen 4mm cable at supercheap (incidently called 10amp cable!) where the conducter would not have been even 1mm^2.
    Note: never accurately measure cable as '5amp' or '10amp' cable. Basic reason is that current capability has a lot more factors than wire diameter alone.
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
  1. Widest rim and tyre size in a ra23
    By ta2313B in forum Tech and Conversions
    Last Post: 04-03-2010, 12:51 PM
  2. 17" tyre size question
    Last Post: 12-07-2009, 07:00 PM
  3. jza70 rear caliper piston size.
    By fixeruperer in forum Tech and Conversions
    Last Post: 20-09-2007, 08:18 PM
  4. URGENT! Nut size for st184 1990 celica drive axle
    By bajachris88 in forum Tech and Conversions
    Last Post: 06-06-2007, 11:33 AM
  5. Old RWD Wheel Studs / Nuts Size
    By Screamn_Sleeka in forum Tech and Conversions
    Last Post: 21-06-2006, 04:51 PM
