i have run mine on 15 psi without any problems for a while... Until recently when something went through my turbo... Not a result of too much boost
Im not sure if you know this already but the 7m has a fuel cut at around 10.5 psi.. You can gat around this by running a HKS fuel cut defender...
On the dyno recently i was running 13.5psi and my AFR was 11.2:1 which is well safe..
The best thing to do is put it on a dyno and gradually raise the boost, that way you will know exactly when you are starting to lean out..
Another point is, if you are running a standard intercooler, dont run over 14psi or you will blow the arse out the cooler..
Stomps
, but still get some OMMMPH
