Results 1 to 6 of 6
Thread: VVTI 2JZ injectors - simple question
    Junior Member Carport Converter spiller's Avatar
    Default VVTI 2JZ injectors - simple question
    Are they the same as non vvti 2jz 440s? I want to use them in my non vvti1jz but I'm unsure if they are compatible...
    1990 JZMA70 Supra SOLD
    2JZ Nut Grease Monkey 98SZR's Avatar
    Jan 2007
    Default Re: VVTI 2JZ injectors - simple question
    The 2JZ vvti injectors are pink and the non-vvti grey from memory, but as far as I'm aware they are the same. I know they are both 440cc and same impedance and fit the same. I'm 99% sure they fit, not sure why they changed the colour, same 2 pin connector too.
    Thanks mate, can anyone confirm or dispute this?
    I replaced a set of vvti 2J 440's with non vvti 2J 440's in a car with aftermarket ECU and the AFR's stayed the same.
    ive been told the part numbers for 1JZ, 2JZ non vvti and 2JZ vvti are identical so that's conclusive enough for me.
    thanks guys
    UK supra boys seem fairly sure the 2jz-gte vvti injectors are 440cc, and they're pretty much the experts. One also claims to have flow tested his to ~440cc
  1. 2JZ VVTi Questions (turbo and injection).
    By Mickp in forum Tech and Conversions
    Last Post: 24-07-2008, 07:07 AM
  2. 1JZ VVTI / Non VVTI Question
    Last Post: 24-06-2008, 12:15 PM
