Results 16 to 30 of 32
Thread: High Comp 4AGE Forged Piston Question
    Default Re: High Comp 4AGE Forged Piston Question
    well after talking with Arias some more and also talking with dangdang on here we have come to the conclusion that the low compression ones in dangdangs engine are working fine with his oil squirters in his bottom end, and Arias have said that there high compression pistons have the same skirt length, so should be alright I am thinking.
    This is the reply I got from them when I told them that there low comp pistons appear to work with the oil squirters.
    well, the bottom of the pistons is almost identical, I think they would clear but I am not 100% sure... we have been making these pistons for several years now and we have not ran into any problems... someone would had said something already if the squirters were contacting the pistons...
    Beeri Meza
    Arias Pistons
    Thank you for using Arias
    Arias Pistons distributor for Eagle Products, Total Seal Rings, Cometic Gaskets
    Quote Originally Posted by RT40Corona4AGTE View Post
    I am going off what was on ParadiseRacing's website.
    http://www.paradiseracing.com/Store/...emart&Itemid=1
    Unsure of actual Arias part number.
    Thats odd. Arias own website: http://www.ariaspistons.com/products/toyota.html only list for 88-92 MR2 and then the 20v. No mention of a 20mm gudgeon 16v piston at all. Perhaps on your next email you could enquire as to the gudgeon pin size, and part number?
    Edit: if you add the item to the cart you get this part number: 3730300 which is what Arias list for the 88-92 MR2
    Quote Originally Posted by takai View Post
    Did the MR2 come with bluetop or redtop bigports? Redtop bigports had the 7-rib block and 20/42mm little/big ends compared to the 18/40 of the bluetops.
    Just depends on what the US got, and in that regard i have no freaking idea.
    Can't remember whether they were blue or red, but they were AFM'd (stupid US emissions regulations.....)
    I emailed them regarding the pin size and yes that part number 3730300 does suit the 20mm gudgeon pins.
    yes, 20.0mm pin
    Beeri Meza
    Arias Pistons
    __________________________________________________ _____________________
    Hi Beeri,
    Can you also confirm the gudgeon pin size (20mm?) for your part number 3730300 please?
    Jul 2007
    if they were made for the AW11 4AGZE then they will be 20mm gudgeon. the only time you will get a piston for the 18mm pin is if the pistons were for specifically the bluetop 4AGE (84-86 in the AW11 MR2 in JDM land afaik)
    hmm so part number 3730300 should clear oil squirters then methinks...
    oregon
    In the USA... 18mm pins disappear @ the beginning of 1988.
    That is the intro to the 4AGZE. The same crank and rods were used the 4AGE, as was used in the 4AGZE.
    Jul 2007
    Quote Originally Posted by oldeskewltoy View Post
    correct, same as everywhere else in the world, just japan got them a bit earlier, from 86 onwards instead of 88. Either way the result is the same, and is probably reflected in that ive never heard of oil squirter clearance issues in any 4A build
    Ahh ok, previously ive never been able to get any certainish date as to the switch over for the US market. In fact the last set of pistons i ordered from CP were 18mm, despite them being for a "Smallport" according to the catalogue.
    May 2010
    TAS
    I'm putting my pistons and rods in tonight, I will measure my skirts to make sure they are the same as the hi comps, if they are then there's your answer.
    thanks dangdang I await your update...
    May 2010
    TAS
    I was so engrossed fitting them in the engine last night I forgot to measure the skirts I had even got my verniers out specifically for the task, apologies. But I can tell you my low comps definitely clear the squirters and their p/n is AP331669. If the high comps have a 20mm pin I'd be pretty damn confident they would be to fit the later model block with squirters. Hope this helps anyways RT40
    cheers mate, I shall roll with the Arias high comps then !
  1. question: Low CR vs. High CR for forced induction?
    By AndyTTR in forum Tech and Conversions
    Last Post: 24-11-2009, 05:11 PM
  2. Tips for my high comp turbo gen 3 3sge
    By trd3sg in forum Tech and Conversions
    Last Post: 26-02-2008, 12:43 PM
  3. very high comp... good engine or worn rings?
    By Vios-GT_07 in forum Tech and Conversions
    Last Post: 09-06-2007, 07:45 PM
  4. 2tgte comp Qs + backyard anti lag Q
    By cooter in forum Tech and Conversions
    Last Post: 09-03-2006, 07:46 PM
  5. High 4AGE Cold Idle
    By toaster in forum Tech and Conversions
    Last Post: 23-10-2005, 03:08 AM
