Results 1 to 9 of 9
Thread: 94 Camry widebody.. steering problem
    Sep 2010
    Default 94 Camry widebody.. steering problem
    i was wondering if any one knows if it's my pump or is it the rack that is on it's way out?
    -any way the steering some times go hard as if the pump isn't keeping preasure..
    but i don't want to buy one to find out it's something else.. any ideas?
    Junior Member Automotive Encyclopaedia eeeyan's Avatar
    Sep 2009
    Default Re: 94 Camry widebody.. steering problem
    Try flushing the system re filling and bleeding and see if there is still an issue.
    Before spending dollars on pump &/or Rack.
    Otherwise i would be leaning towards the pump as i had the same car and i had to replace the pump but my bro who is a mechanic did the flush bleed thing first to try and alleviate the problem.
    Wish I had a F#%ken awesome toyota.. saving for the goodness now.... stay tuned....
    Sep 2010
    Thumbs up Re: 94 Camry widebody.. steering problem
    Quote Originally Posted by eeeyan View Post
    hey thanks for that.. made it a little better, but found out it was the uni joint in the steering wheel hight adjuster. it has never turned so smooth! It's been a great car with very little problems.. even after it spent 2 hours under salty water in the 2008 Mackay floods. apart from this, the only thing i have replaced is the wheel bearings. Cheap to run and reliable.. I've attached a picture of it in the flood
    Sep 2009
    Wow.. if that water had got any higher you probably woulda lost it. If any holdens got that high in the water it woulda been a goner.
    Jun 2006
    in what respect would that water height be worse for a Holden than a Toyota.?
    Junior Member Backyard Mechanic dangdang's Avatar
    May 2010
    TAS
    The polariser may have gotten wet in the Holden and as you know once all the molecules arn't aligned shit falls of em'
    Jun 2006
    Polarisers are mounted high on the firewall.... thats where all the Orgone energy is... Don't you know anything ... although if the moisture gets to the polariser sticker (which I believe acts as a focal point..) well, then you'de be in deep trouble
    Sep 2009
    I was simply speaking to toyota build quality as i bet a similar age holden probably would have leaked like a seive but i bet the toyota was probably a lot better.
    Jun 2006
    I play with a lot of 10 series, they're nothing special mate.
  1. 7mgte ideling problem and pressure problem
    By HAIRY_APES_22'S in forum Tech and Conversions
    Last Post: 25-05-2008, 05:43 PM
  2. RA2x steering box tech Q's
    By Gleno28 in forum Tech and Conversions
    Last Post: 04-07-2006, 11:17 PM
