E-Boost 2 FTWthey are pricy though
Fellas,
Can anyone recomend an electronic boost controller for use in my AE86? The car went over the RTA last week and one of the things it failed on was the 'manual boost tee' boost controller. They said the boost controller has to be a 'set and lockable' type. So, Iam guessing electronic is just the way to go.
There seems to be a few out there, but honestly, i dont know much about them at all. I dont want to spends heaps of money, as its not something i have budgeted for right at the moment.
Someone on another forum said they have a 'Blitz SBC Spec-S' for sale. Brand new for $350. When I did a search on them, most people recomended the 'Spec-R' one. From what I can see, the only differance between the two is the Spec-R has 2 solinoids and the Spec-S only has one. I have no idea what that means..... What is the differance between one or two solinoids? Would the Spec-s be sufficient for my application (4AGTE - 14psi)
This is it-
http://img299.imageshack.us/img299/3892/controllerz.jpg
Any advice or recomendation would be much appreciated ....
Or, if you have a good spare one for sale....
Thanks
JoJo
electronic version is hardly set and locakable thoin fact it would be easier to adjust in cabin while driving than a manual one
2 solenoids makes it more likely to actually control the boost accurately.
Hey JoJo.
I would check with the RTA if an electronic boost controller is still going to be acceptable as these are still adjustable. You could always just run wastegate boost with no controller to pass the RTA inspection and then fit a boost controller later.
The difference is the two solenoids between the spec R and spec S. The twin solenoids tends to have better boost control but from what you have said you are running, a Greddy Profec b spec 2 would be fine and are cheaper then the Blitz items.
If it was me, i would just run wastegate boost to get it passed and then fit a boost controller hidden away somewhere when you need to run the extra boost.
Cheers, Brendan.
MX83 Grande 1jz GT35R buildup here.
http://www.toymods.net/forums/showth...ghlight=grande
Some say that his heart has 6 cylinders. All we know, is he's called,
