what kind of output is Aux 1? is it a ground switching output or a 12v output?
if so how do you have it setup to the pump?
im running a microtech but it has a dedicated fuel pump relay wire...
basically the fuel pump relay is
pin 30 12v fused
pin 85 ground via microtech
pin 86 12v ignition on
pin 87 to fuel pump positive
the microtech will run the pump for 20 or 30 seconds if it does not detect ignition it will turn it off...
if the aux 1 on the adaptronic is a 12v output then send it to pin 86 and then ground pin 85
not sure how relevant this all is though
