Results 1 to 6 of 6
Thread: Mx83 s1/s2 engine mounts is there a differance??
    Sep 2010
    adelaide
    Default Mx83 s1/s2 engine mounts is there a differance??
    Hey all im buying a s1 mx83 it has no motor so i doubt it still has engine mounts, so ill need to buy them with the motor, is there any differance in the mounts? I ask this because how the xmember needs to be s2 to fit a 1j, anyone clear this matter up? Cheers
    Apr 2010
    queensland
    Default Re: Mx83 s1/s2 engine mounts is there a differance??
    rubber mounts are the same but as you said you need the s2 cross member to fit the jz engine. and either jzx90 alloy mounts (10mm back then the jzx81) or jzx81 for the factory fit. (the ones that bolt to the block)
    As mentioned, they are the same but I would upgrade them instead of buying factory MX83 items.
    http://forums.toyotacressida.net/for...ad.php?t=51996
    Sep 2010
    adelaide
    thanks for the replies guys, im talking about fitting a 7m, it has no motor or trans with it so ill have to get a 7m from a wrecker, i was wondering if the 7m s1/s2 engine brackets were differant as the xmembers are, as if the two models used the same brackets wouldnt the motors sit differant between series due to the xmembers
    Apr 2010
    queensland
    cant help ya with the 7m sorry
    Junior Member Grease Monkey twiztd's Avatar
    Aug 2006
    pretty sure the engine brackets are different given they have different part numbers
    series 1 are angled to suit the crossmember, series 2 are a horizontal lower section IIRC
    i can take some pics of the series 1 mounts i have next week
    Now - 1988 GX81 Mark II- 7MGTE, GT35R, TiAL 44m, Microtech, 550cc injectors, R154, Xtreme clutch, LSD.... Low boost tune done = 330rwhp@1 BAR...
    Then - 1989 MX83 - The big scrap heap in the sky...
  1. Turbos 101
    Last Post: 24-01-2007, 07:23 PM
  2. 4agze solid engine mounts, oil cooler/relocator kit questions
    Last Post: 03-10-2006, 05:49 AM
  3. 4AG(Z)E Engine mounts
    By DiZ in forum Tech and Conversions
    Last Post: 05-04-2006, 10:00 PM
