Results 16 to 30 of 37
Thread: 1jz in MA61 making boost problem
    Jun 2009
    Default Re: 1jz in MA61 making boost problem
    hi mate,
    possibly map sensor issue if its not making boost properly?
    I've got a spare one here for a jzz30. i know theyre not interchangeable with jza70 etc coz i tried.
    Also if you wanna check for boost leaks, you need to block your airfilter (i usually just remove the pipe and slap a doubled up plastic bag over it, then fit a hose clamp around the end so it cant leak) then find a vac point on the manifold and put some compressed air in with an air blower (obviously dont go over 10psi!) Just enough so you can hear it leaking without starting the car
    Andrew
    Junior Member Grease Monkey 50RTD's Avatar
    May 2009
    Regurgitated from another thread....
    Quote Originally Posted by 50RTD View Post
    ....but one thing i have done on every car ive ever had anything to do with, is to pressurise the entire intake system with an air compressor (need to rig up a sealed cover plate for the inlet of the turbo to allow for pressurisation) and listen for leaks/spray soapy water on hose unions, blow off valve, intake bungs/hoses etc etc.
    I learnt this on one of my cars on the dyno, it wasnt quite making the sort of curry that it should. Did this, and found a bunch of small leaks around hose clamps and the bov and a few others. Gave everything a quick once over, picked up 70hp @ wheels there and then, around a 25% gain.
    Since then ive seen this often overlooked check technique solve all sorts of problems, especially with airflow metered vehicles, where a leak in the intake system causes the computer to read incorrectly, run rich and generally shithouse.
    -Dan
    May 2006
    Thanks for the help guys. I put the air into it and found two vacuum lines were not connected at all. I then reconnected them and found another leak on the intake side just before the pressurized air enters the plennum. I've hopefully fixed that on too.
    But yet to know because I haven't been able to give the car a quick drive to check for boost.
    Hopefully can soon
    Thanks for the help so far
    Steve
    MKII Supra with 1JZ and R154 = win
    Currently building another 1jz powered MA61
    May 2006
    Need help again guys.
    So the running problem is fixed it runs and idles fine now.
    But it still makes no boost.
    It will rev up from vacuum to 0 on the boost gauge then just
    Stays there. Dosent run bad or anything just runs like a non turbo car.
    What else could it be?
    Also what's the plug for that comes off the 1jz loom straight
    After it comes out of the firewall?
    It's just a small 2 pin plug with yellow and black with yellow wires?
    Drift practise this Saturday night I'm praying to be out in thus rig.
    Steve
    exhaust turbine(s) still attached? Wilbo had one turbo fail soon after putting the 1JZ into his MA61.
    May 2006
    Wouldnt it be running like crap then??
    Steve
    just wouldn't boost
    Jun 2009
    does the car smoke at all? Any strange noises from the turbo's?
    I'd be inclined to say that maybe one of your intercooler pipes has come off or you have a split in one of your intercooler pipe joiners if it just sits at 0 under load.
    Andrew
    May 2006
    Yea that's what I though. So to test it I taped up each end of the piping and pumped some compressed air and it just blew out the tape and I couldn't hear it leaking from anywhere else.
    No the car runs good and dosent smoke so thats why I thought turbos were good.
    Do you think it's worth taking turbos off for inspecting?
    Thanks guys
    Steve
    Jun 2009
    map sensor fault?
    Andrew
    Map sensor fault will still boost, it will just run like shit.
    The yellow and black wires on the 2 pin plug are for the JZA70's heater tap.
    Pull the turbo's off and make sure all the wheels are in good condition.
    It may take half a day, but it will put the mind at ease.
    May 2006
    Thanks. The turbos will be coming off then. Yay
    if you've had a CAT in there all along, have a look at the inlet side for bits of turbine wheel?
    May 2006
    Nah no CAT. I got the turbos off.
    They seem alright.
    Wheels are fine and spin freely. The rear just has a bit of oil around the front wheel.
    Might take them to a turbo shop tomorrow for a quick look and feel
    Just incase.
    Oct 2008
    TAS
    Maybe get under the car and give the exhaust a tap with a rubber mallet, see if you hear bits of turbine wheel bouncing around
    1983 Toyota Celica Supra
  1. VVTi 1JZ engine running rough, low rpms, stalling, lacking power
    By slide86 in forum Tech and Conversions
    Last Post: 17-01-2011, 10:31 PM
  2. MA70 Temp Problem
    By Hibba in forum Tech and Conversions
    Last Post: 06-08-2007, 10:50 PM
  3. 7MGE running temp
    By JesseCrown in forum Tech and Conversions
    Last Post: 17-03-2006, 06:59 PM
