55 psi (over 3.5 bar) is adequate for stock engines. However this is only the case when measured before injectors rail AND under heavy load. If it drops under load then it's the pressure being the reason for misfiring. The pump itself (without fuel pressure regulator in the rail) should give about twice as much pressure.
Is there fuel pump ECU or 2-speed pump control with resistor installed? How did the trouble with misfiring began? Maybe you would search for bent fuel pipe or dirty filters? (that one in your fuel tank, too)
