A quick rundown of the SC14.
Rated RPM: 10,000
Max short term RPM: 11,000
Rated boost ratio: 1.8
Max short term boost ratio: 2.0
So, as long as you don't go beyond 10,000 RPM at the charger, and keep it below 12PSI, the charger will love you.
At 9500RPM, you have the following easy options:
4AGZE crank pulley, Stock SC pulley: 11020RPM @ the charger
4AGZE crank pulley, 103mm SC pulley: 13374RPM
4AGE crank pulley, stock SC pulley: 10260RPM
4AGE crank pulley, 103mm SC pulley: 12451RPM
So, with stock pulleys, you're riding right on the edge of the maximum ratings of the bearings. (Better make sure they're well lubricated, you can only replace the rear ones).
With a 4AGE crank pulley, you'll be safe. (disregarding boost ratio of course, you'll have to work that out too).
Don't forget to replace the rods etc. I know the stock 4AGZE is good for 8000RPM, but I wouldn't be taking a stock motor beyond that. Besides, the charger will be sapping about 12-15Kw from the engine at that speed, with a supercharger you want to build a torque monster, not a screamer.
