Results 1 to 5 of 5
Thread: SR20det into a KE20
    Feb 2008
    Default SR20det into a KE20
    Just starting a project putting an SR20det into a KE20.
    Where should i start and does anyone know anyone that's done this??
    The old One Backyard Mechanic
    Default Re: SR20det into a KE20
    One of the great tools available on this forum is the search facility. Try entering sr20 ke20 and see the world of information avaliable to you. Then you may be in the position to ask some informed questions.
    Feb 2008
    Thanks - logically obvious answer - i found a couple great ones there!!
    Cheers!!
    Feb 2008
    Ok.... Pics to follow but i've finally getting the engine & gearbox all in good nick. Have started cleaning it all back & checking what i need to replace that's perished etc...
    About to plonk the donk in & check clearances around tunnel to see how much changing is in order.
    Need an S13 Red top ECU & LOOM & stock exhaust manifold...
    Colour plans have now gone towards Emerald Green as seen on the newer VE Commodores(sadly)
    Feb 2008
    First shot of the SR20DET mid stripping...
  1. sr20det into ke20 conversion/upgrade
    By toylova in forum Tech and Conversions
    Last Post: 24-09-2009, 02:43 PM
  2. Ke20 Aircon (Retrofit or otherwise!)
    Last Post: 07-03-2007, 08:43 PM
  3. KE20 Front drum to disc conversion guide
    By BSIDE in forum Tech and Conversions
    Last Post: 24-03-2006, 04:00 AM
