Results 1 to 3 of 3
Thread: AE86 Brake Master Cylinder
    Junior Member 1st year Apprentice grey_nomad's Avatar
    Default AE86 Brake Master Cylinder
    Looking for a standard AE86 brake master cylinder (same diameter as original). Can't get one anywhere, nor a seal kit.
    Anyone know of an equivalent that will bolt straight on to the AE86 booster?
    PS: I don't want to go larger diameter just yet, will do that when I upgrade brakes.
    Don't force it... use a larger hammer.
    If it breaks, it needed replacing anyway.
    Henk
    Toyota Grease Monkey rthy's Avatar
    Default Re: AE86 Brake Master Cylinder
    Quote Originally Posted by grey_nomad View Post
    I'm pretty sure you can get them from AutoOne/Repco, got quote from AutoOne for about $250 (or $150? cant remember).
    Otherwise ae71/ke70 should be similar?
    Toyota Sprinter AE86
    Traditionalist Domestic Engineer parrot's Avatar
    http://cgi.ebay.com/ebaymotors/TOYOT...Q5fAccessories
    I bought one a while back. It was an OEM one with the asco name ground off. Only issue is that the brake line out of the nose goes upwards rather than straight out, which is an easy thing to fix. And the loom plug on the low fluid warning is a different type, just need to swap over to yours. It bolts onto the booster via the ADM pattern.
    Mine has a JDM master / booster in which the master bolts onto the booster in a diagonal pattern. What I did was strip out the new one of all parts, seals, pipes, reservoir etc and installed them into my jap body after honing the cylinder.
    Cam mountain I feel different from the ordinary
  1. New or NOS RT81 brake booster, master cylinder
    By StuRT104 in forum Tech and Conversions
    Last Post: 24-09-2009, 11:18 AM
  2. Brake line issues, Line above master cylinder
    Last Post: 08-09-2006, 12:50 PM
  3. Need bigger brake master cylinder on KE70
    By crostek in forum Tech and Conversions
    Last Post: 09-02-2006, 06:12 PM
