Results 1 to 10 of 10
Thread: 1G Stock turbo gaskets?
    Junior Member Grease Monkey Mr Multivalve's Avatar
    Default 1G Stock turbo gaskets?
    Hi, I intend to change my stock turbo's over soon on my 1G.
    Has someone done this before, and can you tell me what gaskets their are that can be replaced and who would stock them ? I figure I should replace any that can be replaced when changing the turbo's over.
    Corona Creed:
    Good to Drink, Great to Drive, keep them separate to stay Alive!
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    Default Re: 1G Stock turbo gaskets?
    I just used the ones from my engine... they were in good condition Maybe a bit of the old super high temp sealant to keep them from leaking at all!
    They can be reused, they're fairly bloody sturdy. That said, make sure you use a bit of sealant unlike I did, I've got a little exhaust leak I need to investigate over the weekend.
    On, and on the inlet side of the turbos I originally made my own gaskets, but this time I just used a bit of goo. Seems to be working AOK.
    suffolk
    Turbo Inlet gasket part number is T17376-88341
    Junior Member Domestic Engineer Karma Supra's Avatar
    Oxfordshire
    There isa Turbo gasket replacement set.. Funilly enough, Toyota sell them
    In all honesty most can be reused fine, but the one of top of the downpipe is not reusable as it is a crush gasket, they are cheap to replace!
    Some kind of BMW
    '97 Hilux Surf SSR-X LTD
    ..::VVTi 1UZ-FE::..
    I simply reused my 1JZ ones. (i'm under the impression that the gaskets cost a small fortune from toyota!)
    As JCMF did I only used silicon on the compressor side stuff, as the stock gaskets are metal crush type gaskets which can't really be reused
    And I also put a very thin layer of high temp silicon on the exhaust side gaskets that I reused.
    i got a set of brand new standard turbo gaskets if you keen pm me
    cheers steve,
    1ggte, 11.22 @122mph
    Ok thanks for the replies.
    I guess I will only know the condition of the gaskets untill I pull off the turbo's.
    Umm I can pm you but I will check out the price of the gaskets as well to see what they are worth.
    Is Toyota the only place that would sell them, or maybe an import place would?
    Corona Creed:
    I got some gaskets made up. Gave the guy my old gaskets and he made new ones fromit.
    Facebook | LinkedIn
  1. The 1UZ Mods Thread
    Last Post: 11-05-2014, 07:19 PM
  2. sealant v gaskets
    Last Post: 30-04-2006, 05:19 PM
  3. New Turbos On Car - Do I Need To Build Oil Pressure?
    By love ke70 in forum Tech and Conversions
    Last Post: 24-03-2006, 11:43 AM
  4. 1JZGTE Stock headgasket...how much boost?
    Last Post: 29-12-2005, 03:40 PM
