Results 1 to 8 of 8
Thread: Bigport 4AGE ECU Plugs
    Junior Member Grease Monkey Schmitt's Avatar
    Unhappy Bigport 4AGE ECU Plugs
    Hi guys
    My RWD 4age loom is missing the 14 pin plug thats goes into the ecu and i have tried to get another one without any luck.
    What i am asking is, is there another ecu from another car/engine that shares the same size plug and pin design.
    If not does anyone know where i can get one from.
    Thanks
    Ben
    south australia
    Default Re: Bigport 4AGE ECU Plugs
    i have a bigport GZE loom that im ripping to pieces. i think it has the same connector on it...(is it yellow?)
    we might be able to work something out......
    My Missus is a Domestic Engineer BradW's Avatar
    As rthy said in your wanted thread, sv21 camry, FTW
    Brad
    Old Corollas never die...
    My KE30
    Robots! dancing robots! Domestic Engineer gearb0x's Avatar
    just for the record, are the SV21 plugs ALL the same? or just the 14 pin one he was after
    Not sure about the other plugs.
    BTW if you get a plug from another car be sure to get a good length of wire ( 6-8 inches) as well. Makes it easier for your sparky to join wires to .
    Brad
    My KE30
    Hoppers Crossing
    theres no other plugs that will fit that i've come across.
    i think i might have one drop me a line if you want it.
    Toymods Club Member Backyard Mechanic Big T's Avatar
    The AE82 Twincam will have exactly the same plug... i've seen a couple at pickies from time to time.
    Eddie.
    4agte finally completed. 234rwkw @ 8125rpm. Tis fun
    Hey thanks for the info guys.
    slide86 yes it is yellow. I am going to try get gregas one as he is closer if not i will let you know.
    Grega mate if you have one i am definetely interested in getting it. I have sent you a pm.
    Thanks
    Ben
  1. 4age 86kw/100kw ecu?
    By trd-st162 in forum Tech and Conversions
    Last Post: 18-03-2006, 01:13 AM
  2. Best 4age ecu???
    By cerby in forum Tech and Conversions
    Last Post: 20-01-2006, 04:46 PM
